·I have a very abnormal noise coming from the front end of my car. It began with a slight popping sound when I hit the brakes while backing up. I thought that the solution to this would be tightening the suspension adjustment cams, however, the problem still exists.
Now there are some other odd noises. I've got tein coilovers and when I go over speedbumps they make a weird squeaking noise and the suspension feels "loose".
I thought that the suspension bolts might be loose so I jacked up my car and tighetened all the bolts to the factory specifications. The upper and lower control arms, sway bar, and others. The problem doesn't seem as bad as it was before, however, it is still there.
I know that some people have experienced abnormal noises with Teins. One fix was to tighten the upper supports above factory specifications. I don't know if this is my problem or not, but does anyone have those torque specifications?
Is there anything that could be lubricated? Does anyone have any suggestions?
Thanks.
Thanks.
