1 - 10 of 10 Posts
im not familiar with the tt auto trans. ive got an auto sc300 is this the same trans? and you do require a core exchange correct?
alright ive got a few cores but what type of price are we talking about and could you give me an estimate on how much horse power it will hold?
WilKillya County Sheriff
Kean easy question for you.. If I do na-t and get the auto tranny built- with a 61trim turbo do you think a stall would be necessary?
SupraForums Manufacturer
Chris,
We reccomend the stall with every built transmission. The transmission line pressure is setup for a looser torque converter and without the TC shifts will be muich more abrupt.
well i will be making much more than 550 at the wheels so ill need a transmission that can handle it if i switched to a tt tranny what would be required? will i need a new drive shaft?
It would be better to have your na tranny built, I'm not sure if the ECU will compensate for the change.
im running aem ems so i dont know that the ecu will be a problem. my goal is around 800 hp w/o the juice but ill need a transmission soon and i need something reliable
Mid-life Realization!
A built toyota tranny would be a mis-match for a set-up with those types of power goals. A BL400 or similar is likely a better choice for reliability. Eventhough the initial cost will be substantially higher, going through built toyota trannys and the associated downtime will quickly become more costly over time IMO.
Brad
1 - 10 of 10 Posts
