·Is there a better way to eliminate the EGR besides the the block and the resitor. It seems that I am loosing air at the green EGR canister. Any help is appreciated.
www.mkiv.com has both plate and removal mods.chester said:Is there a better way to eliminate the EGR besides the the block and the resitor. It seems that I am loosing air at the green EGR canister. Any help is appreciated.
I had the same leak at the EGR, I installed the thin sheet steel plate that Mohd (mkiv.com list) sells, no more leak. I just remove it to smog and then reinstall. Easy.chester said:Is there a better way to eliminate the EGR besides the the block and the resitor. It seems that I am loosing air at the green EGR canister. Any help is appreciated.
Install is really easy, if you don't have the correct Torx head socket (to remove the studs) then notch the plate where the bolt holes are so you can drop it in from above.chester said:Chip,
How hard is the install and do you know of any advantages in this over doing the egr removal and using two plates?
