If I remember it correctly the H&R spring lowers the car quiet a bit... now this is what you do... go jack up the car and take off your front wheel and see if your tire have rubbed a hole thru the fender cover.... now if there is a hole thats most likely your problem... it probably rubbed thru and cut the wires which connects to the wheel sensor... that is why I took the whole thing apart and soldered the wires back together... and also ran the wires higher up so it doesnt get cut again... so just check I am almost for sure that would be your problem that the wheel prolly rubbed thru and cut the wire.... so good luck.... e-mail me or PM me if you have any other problems...
