1 - 4 of 4 Posts
I normally don't run with the AC on as I like to drive with the windows down. But I turned it on the other day and the revs never went up during idle, so I figured it was a dirty IACV. I took it out, cleaned it out and put it back. Car seems to idle better but when turning the AC on, the rev's do nothing (they just stay normal), but I do see a change in my idle AF (leaner). Any suggestions?
micheal... it doesnt change the rpm if the AC compressor isn't kicking on... if your ac is not kicking the compressor on or blowing out cold air then you might be low on freon therfore the ac compressor wont turn on due to low freon...
1 - 4 of 4 Posts
