1 - 3 of 3 Posts
hey all, while doing my auto to manual swap, i noticed that the flex plate bolts were too short to bolt the flywheel to the back of the crank, so i used a rubber mallet and tapped the flywheel closer to where i could use the bolts that originally fastened the flex plate.
now after mounting and bolting in the tranny and everything else i hop back on the forums only to read that the flywheel bolts are longer than the flex plate bolts!!
would there be any problems from using shorter bolts??
· Premium Member
yeah... if you go high enought in the rpm and those bolts break, so guy bye to the tranny tunnel cause something that is rotating 3krpm+ flying out of the transmission= major damage... aight peace :chicken:
1 - 3 of 3 Posts
