1 - 20 of 250 Posts
Hello everyone,
My name is Adam G, I have been lurking around the forums since I owned my first 1995 White NA 5spd in 2003. I was out of the Supra game due to college expenses for a few years and found my way back in 2011-2012, then joined as a member. I just wanted to say that many of you without even knowing it have inspired me to pursue my dream of building a supra and customizing it to my desire. I just wanted to say thank you for those who have helped me, for those who have inspired me, and to those who have had my back throughout the entire process so far. I am nowhere close to being done, as this is just the beginning. This is not a crazy 1,000 HP single build and will not be exciting to a lot of you guys, but I have put a lot of $ and effort into this so I hope some of you enjoy.
I purchased my 2nd MKIV in April of 2012 after 6 months of research and saving. I stumbled across a for sale ad from Owensboro, KY. It was an ad for a 2 owner (leased for 2 years, then owned for 17 years) bone stock, clean, 5spd NA supra with appx 140K miles on it. The car had been garaged for a few years and was owned by a priest, yes a priest. It had the Jesus fish sticker on the back of the car and all. After reviewing the condition and maintenance records, I drove down to KY two days later with cash in hand. Tires were dry rotted from sitting, headlights were fogged out, leather on seats luckily had been replaced two years prior, body and paint was in good shape for a black 93.5, it had a rough idle and you could also tell the clutch had never been replaced. After a test drive and quick inspection, I knew this was the platform to build my dream car and hopefully some day pass it down in the family whenever I leave this world.
After a year of owning the car, I started on the basic OEM upgrades (headlights, taillights, turn signals ect). Got married in 2014 then started saving for the GTE swap. My wife is such a huge advocate of me following my dreams to build this Supra. She has been there every step of the way.
I pulled the GE motor in late February 2015 after returning from our Honeymoon in Jamaica. Purchased a non-vvti 2jzgte aristo motor the following week. So this is an aristo GTE swap into 93.5 NA 5spd MKIV. Full USDM conversion. Staying on stock twins for now with W58 until full drivetrain upgrade is feasible, then onto single upgrade.
Here is a list of mods that have been added to the car since I purchased in 2012:
2JZGTE non-vvti aristo (appx 40 – 50K miles)
USDM Turbos (70k miles)
USDM camshafts (75k miles)
TT Ignitor
TT resistor pack
550 CC Injectors
PHR Fuel Dampener Bypass line (black)
New Toyota fuel filter
Walboro 341 fuel pump upgrade from PHR
TT fuel pump ECU
BNIB USDM OBD1 wiring harness
OBD1 G-Force 6spd ECU
Titan V2 black Cam Gears
Full engine gasket kit – Toyota
Head fully cleaned with new valve stem seals and shaved for new head gasket
ARP Headstuds
HKS Carbon ti exhaust
Tanabe downpipe
BNIB Greddy 3 row FMIC
97-98 headlight
97-98 taillights
97-98 turn signals
USDM TT water pump – Toyota
New Oil Pump- Toyota
Belt tensioner and idler - Toyota
Swapped over NA PS pump and AC pump
TT dipstick and tube
New complete vacuum hose setup for stock twins - Toyota
New spark plugs (NGK)
swapped over NA upper and lower oil pans with new Toyota sealant
Y pipe for oil return turbo with new hoses
Mishimoto X-Line radiator
Toyota radiator coolant hoses (new)
Toyota Heater hoses (new)
Painted spark plug cover black
TT 17” wheels resurfaced and painted a glossy silver
TT brake setup (used low mileage setup)
PHR Stainless brake lines (charcoal)
Clutch Master FX400 clutch kit (with new OEM clutch bolts)
W58 OEM flywheel resurfaced (new OEM flywheel bolts)
Redline manual tranny fluid
Swapped over reverse light and EA2 fuse box connector from NA harness
Toyota Thermostat replaced
Painted engine block Flat black
Fuel pressure up VSV
TT timing belt - Toyota
TT drive belt - Toyota
New idler pulley
Used MAF and new Toyota Turbo inlet pipe that connect from MAF to turbos with clamps
MAX Air intake box with new K&N filter
06 Honda Civic coolant overflow tank
Aftermarket Front lip (New)
OEM belly pan cover (new)
License plate light covers (rear)
97-98 3-Spoke Steering wheel
Dash Pad (new)
Complete set of new 93-96 dash panels
Windshield Wiper Cowl (new)
Differential covers (new)
Front Speaker Grilles (new)
Trunk hatch Foam L and R (new)
OEM subwoofer w/ enclosure (new)
Rear Hatch plastic trunk panels (3 - new)
Lug nuts (new)
OEM Black floor carpet (new)
OEM rear hatch carpet (targa model) (new)
floor and hatch carpet hardware/plastic clips (black)
SHIT TON of other hardware replaced...
New OEM Odometer from Denso programmed to exact mileage
OEM Rear Hatch Cover with retractors and clamps for the tonnaue cover
Rear hatch struts (aftermarket)
Rear hatch rubber bumpers and stoppers with hardware
All three wiper arms (New)
Volk SF Challenge wheels 19x8.5 and 19x9.5
TRD Motor mounts
Discussion Starter #2
Pics will come soon, having some computer issues. The car is not running yet, I still need to wire in the TT fuel pump ecu. She is turning over but not starting. Manually ran the pump and got fuel to the fuel rail. Pump not turning on with key.
IMG_0692_zpso54yzwxo by Adam Gibson, on Flickr
WIndow tint 20%
IMG_0726_zpsyflzrxtf by Adam Gibson, on Flickr
Picked up a OEM black wing
IMG_0732_zpsyb3bv839 by Adam Gibson, on Flickr97-98 Headlights
The top headlight was already refurbished, the new headlights make such a huge difference
IMG_1684_zpsyoahsx1g by Adam Gibson, on Flickr
IMG_1756_zpsxoanerdk by Adam Gibson, on Flickr
The Supra sitting with my brother in laws custom audi for Easter Brunch
IMG_1766_zpsq5cmtyzq by Adam Gibson, on Flickr
Subscribed as I picked up my black NA auto this year! Threw on the W58 already, saving up for the aristo motor and accessories so i can knock it all out at once :)
Discussion Starter #9 (Edited)
She loves the Supra
IMG_0297_zpsmx0kar77 by Adam Gibson, on Flickr
My friend Justin doing a full paint correction then 3M buff and wax job
IMG_1106_zpsccwwmqlc by Adam Gibson, on Flickr
IMG_1097_zpsi7sowyme by Adam Gibson, on Flickr
IMG_1144_zps1cvnztqh by Adam Gibson, on Flickr
IMG_1150_zpsdydoojsr by Adam Gibson, on Flickr
Picked up these from the forums. Great fit!
IMG_1177_zpsmhwn1hwc by Adam Gibson, on Flickr
IMG_1242_zpstd7uz90g by Adam Gibson, on Flickr
Head unit upgrade, this thing has some pretty cool features
IMG_1292_zpsby556eut by Adam Gibson, on Flickr
Got a good deal on a set of TT stockers. Needed some curb rash repair and paint.
IMG_1219_zps2n6ncemt by Adam Gibson, on Flickr
IMG_1231_zpsjwcods2a by Adam Gibson, on Flickr
Discussion Starter #10 (Edited)
Discussion Starter #11 (Edited)
Well, On to the fun part. Started getting massive boxes from Curt at Emlhurst.
IMG_1530_zpstloo8qkv by Adam Gibson, on Flickr
IMG_1490_zpsynyi9yn4 by Adam Gibson, on Flickr
IMG_1536_zpsojuuul9d by Adam Gibson, on Flickr
Used 20K miles break setup purchased off the forums
IMG_1630_zpso04k69kg by Adam Gibson, on Flickr
IMG_1603_zpscwahw7rd by Adam Gibson, on Flickr
When the 2jzgte arrived (Time to put in some work)
IMG_1626_zps13rlo9ci by Adam Gibson, on Flickr
IMG_1686_zps7h3tc8ct by Adam Gibson, on Flickr
IMG_1693_zpszb4l0gof by Adam Gibson, on Flickr
IMG_1702_zpshciojthq by Adam Gibson, on Flickr
I know many of our fellow members have been in this position, they all have done the same thing
IMG_1705_zpsenglimpf by Adam Gibson, on Flickr
Hello Hello
IMG_1670_zpsj36sjvhh by Adam Gibson, on Flickr
IMG_1663_zpsto3vnucw by Adam Gibson, on Flickr
Discussion Starter #12 (Edited)
Tear down initiated
IMG_1738_zpsbon71bju by Adam Gibson, on Flickr
IMG_1768_zpsi7q5h78q by Adam Gibson, on Flickr
IMG_1765_zpsb4jyjq7e by Adam Gibson, on Flickr
IMG_1752_zpsgmjf6u9m by Adam Gibson, on Flickr
Clutch Masters FX400 Clutch kit 6 puck ceramic disk
IMG_1775_zpsyhmzqk12 by Adam Gibson, on Flickr
Old motor getting yanked
IMG_1816_zpsstcick2p by Adam Gibson, on Flickr
IMG_1814_zps9eixjpvj by Adam Gibson, on Flickr
She was dirty
IMG_1826_zps4aq6hy5r by Adam Gibson, on Flickr
IMG_1819_zpsu8979hzj by Adam Gibson, on Flickr
A little time and the bay cleaned up pretty well
IMG_1877_zpsdsnx0jdx by Adam Gibson, on Flickr
Drinking a beer with my wife after a long work week. Too tired to work on the car, Beer is good.
IMG_1947_zpsowq2eken by Adam Gibson, on Flickr
Down to the block
IMG_1950_zpseeu3bbpo by Adam Gibson, on Flickr
IMG_1991_zpsupzmuqjs by Adam Gibson, on Flickr
My wife literally hates me at this point (6 months into marriage)
IMG_1971_zpst8mgztpk by Adam Gibson, on Flickr
Dropped head off for cleaning, new valve stem seals and shaved within factory specs for new headgasket replacement. It turned out great!
IMG_1998_zpsosccrekb by Adam Gibson, on Flickr
IMG_2002_zps7ct2vlet by Adam Gibson, on Flickr
IMG_2006_zpsafp0glc6 by Adam Gibson, on Flickr
Discussion Starter #13 (Edited)
More goodies
IMG_2122_zpslmo4avvw by Adam Gibson, on Flickr
Downpipe/midpipe
IMG_2125_zpsq0ljsrcr by Adam Gibson, on Flickr
Rear Sump oil pans going on. You can see the studs for the oil return lines that had to be drilled/tapped. Just cleaned the pans up a bit before new sealant.
IMG_2128_zpsm9iv6s4w by Adam Gibson, on Flickr
ARP Headstud kit, new oil pump and water pump
IMG_2135_zpso93nfjxc by Adam Gibson, on Flickr
IMG_2143_zpsyayo6vvz by Adam Gibson, on Flickr
IMG_2151_zps4rzg0tup by Adam Gibson, on Flickr
USDM camshafts and titan cam gears on. Motor timed with new timing belt on.
IMG_1897_zps5dewpl5i by Adam Gibson, on Flickr
IMG_2158_zpsklmew31e by Adam Gibson, on Flickr
IMG_2160_zpsx23gg6fd by Adam Gibson, on Flickr
IMG_2178_zpsbzb6zluy by Adam Gibson, on Flickr
Discussion Starter #14 (Edited)
550CC injectors, new o rings from the full engine gasket kit from Curt.
IMG_2211_zpsas6rxxhk by Adam Gibson, on Flickr
IMG_2212_zpswb81ovbv by Adam Gibson, on Flickr
well, we are getting there.
IMG_2218_zpsx2qfbduf by Adam Gibson, on Flickr
Hoosier rigged the downpipe
IMG_2241_zpsyzzbvmyc by Adam Gibson, on Flickr
IMG_2247_zpsjmg3th1u by Adam Gibson, on Flickr
PHR fuel dampner bypass line
IMG_2276_zpsxmusfyuq by Adam Gibson, on Flickr
Test mounted the USDM twins
IMG_2290_zpse36oulvl by Adam Gibson, on Flickr
Time to start wiring the new harness up. It actually lays perfectly once you find the way it sits.
IMG_2354_zpsgmdw8j9q by Adam Gibson, on Flickr
IMG_2370_zpsypzkevtt by Adam Gibson, on Flickr
Discussion Starter #15 (Edited)
The flywheel resurfacing really came out great
IMG_2415_zps0gbqg4i3 by Adam Gibson, on Flickr
IMG_2425_zpsngub9ztz by Adam Gibson, on Flickr
IMG_2860_zpsuis3jiqm by Adam Gibson, on Flickr
Heater hoses, pretty much all vacuum hoses on the turbo side, coolant bypass hoses, turbo oil hoses, ect
IMG_2531_zpsuojdzp7f by Adam Gibson, on Flickr
This part is fun
IMG_2558_zpsflnisfzm by Adam Gibson, on Flickr
Trying to multitask. The Intercooler core is a tight squeeze but fits nice and snug.
IMG_2322_zpsfizs5xkr by Adam Gibson, on Flickr
IMG_2340_zpserhthj79 by Adam Gibson, on Flickr
IMG_2326_zpsgwefkiav by Adam Gibson, on Flickr
IMG_2628_zpspmexrxe3 by Adam Gibson, on Flickr
IMG_2602_zpsvbobmvvy by Adam Gibson, on Flickr
IMG_2816_zpsismbayts by Adam Gibson, on Flickr
locking clamps on all these hoses
IMG_2636_zpsvtckyecx by Adam Gibson, on Flickr
IMG_2639_zpsiyrdinzy by Adam Gibson, on Flickr
Front Lip on
IMG_1740_zps6atmeyf5 by Adam Gibson, on Flickr
IMG_2788_zpsbay6as5w by Adam Gibson, on Flickr
Discussion Starter #17 (Edited)
Almost ready to drop in
IMG_2608_zpsn7wcylpa by Adam Gibson, on Flickr
IMG_2882_zps0c4ykgoe by Adam Gibson, on Flickr
IMG_2847_zpsxfqcdjij by Adam Gibson, on Flickr
Test fitted the motor, she sat right in. Had to pull it out to attach heater hoses and then bolted it down.
IMG_2886_zpssyqzjtsd by Adam Gibson, on Flickr
IMG_2890_zpsrdx5vayx by Adam Gibson, on Flickr
Its been about 6 months since I have seen my shift knob haha
IMG_2896_zpssoclvtg5 by Adam Gibson, on Flickr
Doing the driveshaft
image1_zpsibv3qfoa by Adam Gibson, on Flickr
IMG_2970_zpsmhc6icti by Adam Gibson, on Flickr
IMG_3086_zpsndz48ydy by Adam Gibson, on Flickr
IMG_2937_zps8sc7nwnv by Adam Gibson, on Flickr
Used max air setup, cleaned the K&N filter
IMG_2979_zps5zrrp1ev by Adam Gibson, on Flickr
I also thought this photo would be cool to share. My grandmother made this and gave it to me at my wedding.
IMG_3059_zpsrdrvvgl7 by Adam Gibson, on Flickr
Upgraded the fuel pump to walboro 341 on the NA hanger, PHR send me the install kit and pump.
IMG_3099_zps3uyo4hys by Adam Gibson, on Flickr
Discussion Starter #18 (Edited)
IMG_3117_zpsajcfltvt by Adam Gibson, on Flickr
TT fuel pump ecu on the left, NA on the right. just received the body harness clip for the TT fuel ecu.
The car is not gettting fuel on turn of key, hopefully this ecu will change that. Able to bypass and manually run pump to get fuel to rail, but no start. Turnover sounds good.Will keep you guys updated once the ecu is in. If not I may have to check my 6spd USDM main ecu
1 - 20 of 250 Posts
