1 - 7 of 7 Posts
Has anyone played around with their adj cam gears using 264's? I know most say leave them at 0deg, but im wondering if I should retard it a couple degrees on the exh cam when using a 76 on stock head.
Any input?
thanks ryan
Boostin...
I will throw it on the dyno in a couple of weeks and I'll let you know Ryan. :)
Moderator, l337 M0d3r4t0r
everyone's cams are diffrent I've seen people use oen setting and loose on another car with the same setup.
best is to dyno to be honest.
Do not rule out retarding just the intake cam a few degrees. I would try it on a dyno and see if you like the results
1 - 7 of 7 Posts
