If you have time, play around with them on the dyno or on a "test and tune" drag day -- just be sure to reset your timing each time you set the exhaust cam otherwise you might be seeing differences from ignition timing instead
exactly.. you just cant use someone esles settings because all motors/cars are different... dyno tunning is needed for the best resultsma71supraturbo said:If you have time, play around with them on the dyno or on a "test and tune" drag day -- just be sure to reset your timing each time you set the exhaust cam otherwise you might be seeing differences from ignition timing instead
