1 - 9 of 9 Posts
I am looking for a new set of adjustable cam gears, and was curious what everyone recommended? The market is a lot different than it was 5 or 10 years ago, not as many options. The Powerhouse ones looked interesting, with the available adjustment kit and locking tabs for each degree.
Looking for function over form as the cam cover is always on. Would be nice if someone made ones with steel teeth, as the aluminum always wear out eventually.
I have ran HKS gears the last 18 years. While they held the adjustment just fine, they are finally wearing down a little - mostly the exhaust gear. I guess that one takes the most wear since the belt comes around on that side.
Thanks,
Al
Super Moderator
Al,
You can't go wrong with the PHR cam gears but another alternative you may want to consider are the Titan cam gears. I have them on my red car and they have treated me well over the years.
Ken.
Looks like Titan, can't beat the price.
That's one thing I'll say about my HKS V1 gears - lots of information on there - tick marks for 1, 5, advance, retard, etc. The current trend appears to have one reference tick mark, and that's it. It's nice to have a quick reference while adjusting, instead of having to think about which way is advance, retard, etc.
No more Unorthodox cam gears for 2JZ from what I can tell.
Al
Boost Junkie
I believe the PHR cam gears use a steel teeth as do the Titan ones. I've seen some broken Titan gears as well. I run the Titan, but I do have to say I am a bit cautious about recommending them due to the broken gears that turn up from time to time. Make sure you get the Titan specific ARP cam bolt.
I'll eventually switch to the PHR as I like the functionality of the locking adjustability.
Steve
Discussion Starter #6
Damn, I might as well keep using my HKS ones. They have been reliable, just getting worn.
A broken cam gear is unacceptable. Everything I have seen has said billet aluminum. Titan doesn't list a bolt for it. PHR does, $25 each, lol! For all the bells and whistles, you are over $500.
Al
Boost Junkie
You just need to use the ARP bolts that TItan has on their website. The washer is slightly smaller in diameter than the stock one.
Steve
Discussion Starter #8
But if they have had problems with the gears, I can't run that one. They don't mention anything about bolts, have not yet found them. You'd think if it was important, they would try to sell you those with the purchase of cam gears.
One issue is the hole for the cam dowel pin is a large "slot". I don't see how the gear could properly align with that much slop. Unless it just appears that way in the picture.
Al
Boost Junkie
Yea, mine didn't have any slop. I have GSC S1 cams.
Steve
1 - 9 of 9 Posts
