1 - 3 of 3 Posts
hey i just installed an AEM adjustable fuel pressure regulator and am curious which one of the 3 inserts should i be running i have a walboro fuel pump and stock injectors also what pressure would be good?
thanks
and yes i did a search and didn't find what i was looking for
Unclipped Fury
That really depends on how much boost you plan on running.
30-40 lbs might be a good start, unless you wanna run serious boost. If you plan on runing stock ct20 under 15 lbs, then there is really no need for the AFPR. But it does look cool.
1 - 3 of 3 Posts
