Mods: AEM WBo2 sensor Walboro255 580cc Simens Injectors AFPR/w fuel pressure gauge 2.5" hardpipes Lexus AFM and all the necessary internal mods ARP head studs MHG.
Symptoms: The car wont start, but if I have someone hold a folded rag over the intake to the AFM (theres no filter currently on it) the car will start but run very rough as well the boost gauge showed 0 not vacuum and off the WB lean. I pulled off the AFM connection and removed the IC hose from the throttle body and the car started and reved from 1000rpm to 3000rpm and then back down to 1000rpm. During the time the car was reving up to 3000rpm the boost gauge showed proper vacuum as per TSRM and showed 13.5 to 14.7 on the WB.
What I have done so far:
Changed: AFM, TPS, coil packs, igniter, cps.
Cleaned and checked continuity for the fuse box in the cabin and under the hood
I also checked continuity between the TPS to ecu, AFM to ecu, coil pack to igniter, cps to ecu, and igniter to ecu.
I checked the tps, ecu, afm, coil packs, and igniter as per TSRM.
My theory: If the AFM is working properly and I am getting spark and fuel and firing at relatively the proper time then what would make me run so lean and not pull any vacuum. I assume there must be a place where more air is getting in to make it run lean, but then how does that explain the no vacuum?
WHAT THE F IS WRONG PLEASE HELP!
SF vets please help me I would appreciate any comments or suggestions.
Dave
Dave
