B
blue_3li
·Guest
need some advice guys
my car is having some brake issues - the pedal pressure is very high, it doesn't depress almost any distance at all, but i can still brake by pressing harder on the pedal.
also, when i roll to a stop, it jolts to a stop by itself, instead of smoothly decelerating.
the problem comes and goes, but recently have been getting worse. usually if i park the car and let it sit for some time, then the brakes return to normal, but now its starting to stay around longer.
im pretty sure the brakes are stuck somehow, but what should i do? bleed the braking system? change pads? change calipers?
i was thinking maybe because of the turbo, somehow it is heating up the brake fluid and perhaps getting it stuck with junk? my turbo has no blanket/heat shield.
thanks for any help in advance!
