1 - 1 of 1 Posts
I want to use egt sensor input #3 for a 0-to-5 volt signal from a fuel pressure sensor, but it’s showing no signal in AemPower software. I checked all wiring and it’s good. The first 2 egt sensor inputs work perfect, but why is egt #3 not showing any signal?
EGT #1: Aem rtd-type egt sensor (wired with sensor ground wire as Input and 2nd sensor wire is connected to Aem Reference 5 volt wire)
EGT #2: ProSport Oil Pressure Sensor (12v power, battery ground, 0-to-5 volt output signal)
EGT #3: ProSport Fuel Pressure Sensor(12v power, battery ground, 0-to-5 volt output signal)
1 - 1 of 1 Posts
