1 - 9 of 9 Posts
Boostinhard said:
so who has some decent anit lag settings ?
what kind of turbo are your running? transmission set up? etc
they all are key into setting up the antilag option!
once i have this info i can point you in the right direction
(btw due to EGTs sometimes its just better to run the 2step with ign retard on a hard cut... antilag can severly hinder the life of the turbo but the 2step will only slightly shorten the life)
first off... were not supposed to talk about that again because of reasons you should remember
second off i forgot i had a cat on the car
dont mind urbancustoms... he just follows me into every thread i post and says something
HyperHoHo1 said:
Try this...
5950 Fuel Cut
5650 Ignition Cut
5350 Retard
im assuming those are 2step settings for a 6speed car?
here are some antilag settings for guys on auto with 3600 with small turbos
Alt Ign Fixed = checked
Alt Spark Fixed = -15.00
Alt Spark Trim = 5
Alt Fuel Trim = 12%
Alt Off Over= 3800
Alt On Over= 3400
Alt Off Under TPS = 50%
Alt On Over TPS = 75%
Alt Overboost = 20psi
Alt On Above Load = -14.69 psi
then just set a switch...
i was able to build 15-17psi on the line with that
1 - 9 of 9 Posts
