1 - 8 of 8 Posts
Anyone had any luck with wiring this unit. I assume that my wiring is correct being that using the bypass plug with the stock ignition works fine. Another thing is that the redlight light on the unit is not lighting up. The instructions are also misleading the switches in the instructions say down is off, if you look on the unit is says down is on.
RacingTechnology said:
Get an Autronic CDI
They make a 6channel? Cost a zillion bux right? No thanks.
Just wired this on my car today. The two left hand switches are down, the far right one is up. This is for normal 720 firing on an 8channel, multispark is on. I just wired up 6 motorcycle coils on my car and will be driving it tomorrow so we'll see how it goes. I'm on an AEM but it should also work on OEM ECUs fine as it's post ignitor. I DId have to knock dwell way down on my AEM so I'm not 100% sure that the OEM ECU would work out so don't take that as gospel...
Oh, the LED fires for 10ms after each ignition trigger. It will glow DIMLY while idling...
how much for either one? Rob NJ.
1 - 8 of 8 Posts
