1 - 10 of 10 Posts
If I plan on running an AEM EMS should I get a seperate boost controller or use the AEM to do it? :scratch:
Newbe....I know nothing!
The AEM one works fine if you know how to set it up.
Jeremy
Moderator, l337 M0d3r4t0r
I don't know should you?
it's all prefrence...
AEM EMS is basically everything needed in one thing...I'm assuming thats why its so expensive...but if you want a BC go for it...
2JZ Mk2
If you always change the boost settings a seperate controller is easier. Mine is set at the AEM and never changed so a sepeate box is a waste.
25psi Bliss
That's a ~$1500 question.... :scratch:
You can use it and marry the standalone features with the OEM AFM, but I'll state that anyone with any standalone ultimately run thiers in speed density mode.
xrated89 said:
with the aem do you still need an afm???? sorry to thread jack just curious
2JZ Mk2
GM IAT sensor
GM MAP sensor
for speed density
with the boost solenoid and all the connectors it was ~$157 from Fred Beans shipped
1 - 10 of 10 Posts
