Hi I have a Toyota Supra MKIV. Run with a aem ems and each time I activate launch control for example 5000rpm i can use the launch control but then the car just run at 5000 when i drive then the launch get active, was heard what i have to solder some wires so launch control is active only when the car is stationary, but which cable is it if so?.
Or how can I fix the wrong? Sorry for my english :).
I don't have AEM installed yet but I thought it used the VSS (vehicle speed sensor) so that it only works at vehicle speed < 2mph (user definable)
This may be better answered on the AEM forums, good luck!
I have mine to work anytime im under 15mph. depending on how high you are going to launch it can make the burnout a little difficult. if your set for 3000 rpm. you'll have to start your burnout at 3000rpm also. I have mine set for 3800 and i don't have an issue as long as i roll thru the water box.
