Moderator, l337 M0d3r4t0r
Can someone post a base map that I can load in the demo software to get an Idea of what I’ll be doing after i get my EMS.
I want to fool around now so when I get it I have a good idea of how to work it.
For you 1jz guys I'd especially like a map form you.
Any nuggets of info that you have and you want to share?
I know the AEM forums are around but they are pretty stagnant in the mk3 section
Thanks,
Not so boring anymore
my basemap is in the basemap thread in the 1jz section.. i will update it with my current map when i get home (modified a little, little less timing and better a/f in cuising, getting better mpg)
well heres a link to it
http://home.cfl.rr.com/tissimo/1jzbasemap.V1.11.cal
its a 1.11 cal.. i havn't converted to 1.19 yet..
RoastBeefCurtain Commando
have fun dude.
i worked with AEM a while ago and it deff takes some getting used to . I was deff overwelmed with it.
It sucks, but I might end up running it on mine too.
Yo , let me kno on that harness from Autosport wiring.
Madd Tyte JDM yo ®
if you go on AEMforum.com, there is a writeup on how to generate a basemap for stock sensors and injectors. it also tells you how to scale it and stretch it and whatnot. i was able tomake an 18psi map from nothing on my friends 2j... it would have worked too if the damn Map sensor wire wasnt inserted into the AT OD lockup slot on the ECU... fuckin Garage Advance...
