I'm trying to do some pre-checks on the newly installed AEM before I actually fire the car up. So far, I've got injectors working as validated by a node light. Moving onto spark, I seem to have nothing.
I hooked the igniter up and the harness that goes to the coils (coil on plug). I plugged in one coil and one plug and grounded it out to see if I was getting a spark. Nothing. So, in tracing the problem back, I then thought I could have a bad igniter. Tracing farther back yet, I found I'm not getting any signal to the igniter so the EMS must not be triggering the spark.
The image below is of the parameter list while I'm cranking the engine. One can see that the cam is sync'd correctly, but the 3 coil drivers (I6 engine with wasted spark) are marked as being "OFF". In the options, I have them checked as "Active" so I know it's not something dumb like that.
Any thoughts or things to try? Any other values look out of wack? I realized that I don't have an IAT listed below which is sorta important with a MAP setup so I'm going to check that too.
