81 - 87 of 87 Posts
JetFire
I have this issue for the last 3 seasons, ive replaced the stock ignition system by a r35 coils conversion and the cutting is over !! Engine runs way smoother in lower range and idle !
Good to know, you just swapped to R35 coils and it went away?
Discussion Starter #83
I STILL have it.
if you guys catch it on a log, it should show the crank sensor misses a revolution, which causes the injector not to fire, which shows a spike in fuel pressure. At least thats what mine does.
I called AEM and talked to another tech. he said to adjust the VR_pwmduty. To do this, open the Infinity 506 layout (the 710 layout doesnt have it for some reason. he said the 506 is more updated than the rest)
go to the cam/crank tab
lower left side you will see VR_pwmduty. the value should be at 95. he said to adjust it to between 92 and 97.
ive adjusted it both ways, numerous times and the issue still persists. its really really annoying!
Mamba Still On Top
I STILL have it.
Bump for this still existing. First time I've heard AEM admit awareness of the issue publicly.
Space for sale
Anyone able to fix their hiccup issues with adjusting their VR_pwmduty? I will have to try it out when the weather is nice enough to drive.
Have you guys o-scope the crank/cam signal as this takes place?
On VR, when you drop signal to 0, that might indicate that the VR sensor is shorting to ground. Only way to really tell is to do an o-scope capture at the same time to actually see the waveform and to validate that it is indeed dropping.
81 - 87 of 87 Posts
