AEM map for 1000cc injectors and 80mm turbo
708 Views 18 Replies 11 Participants Last post by  93 twintrbo
Anyone have a basemap I can use to start the car? The car will be tuned on boost comp if that matters or not.
Thanks in advance and I could have sworn I seen this posted before but damned if i can find it.
1 - 19 of 19 Posts
Did you get a basemap yet? PM or email me if not...
No sir, not yet. PM coming your way and I really appreciate it! If you werent a thousand miles away the dawg would be coming to your shop
what map sensor are you running?
John reed ...
Do u also have a 1000cc power fc d-jetro map for an rb26dett GT-R ..by any chance ?
AEM 5 bar map
Well my car has a 3.5 bar map. I can send you my map if you want but you are going to need to re config for that map sensor. I am not sure how good the wizard will do the change but it will probably get you running and idling I would think.
Let me know and PM me your email and I will send my calibration.
Bob
TTT still needed. Anyone?
Still looking for a basemap since September? Neither Mr. Tompkins' or Mr. Reed's calibrations would get the car running?
IIRC, BLKMGK made a whole bunch of basemaps and posted them up on the AEM forum a long time ago. He made them for nearly every concievable parts combination. I bet you could dig the one up for your setup from there if you need something to get started with. Also, most tuners will email you something so you can drive to thier shop (no boost).
Bobs was for a 3 bar map and mine is a 5 bar. I dont have a clue how to convert it. John Reed never PMed me back LOL.
Thanks for the advice dude, Ill check over there!
Use bobs map and change the sensor its super easy.
go to (setup, sensors, map sensor, map sensor wizard, select AEM 5 bar "enter") and your done.
Matt
Matt
Yeah, good idea. Then wonder why the engine keeps on blowing up (You just stretched 3.5 bar worth of ignition timing out over 5 bar worth of pressure).
Slither, if you still haven't found anything, I may be able to dig something up for you off of my tuning laptop and upload it to the internet friendly one. LMK.
Base maps arent made to be boosted on. You need to fully tune the car after the bas map is loaded. Yes even if it came off someones car that ran great.
Not to mention if you dont know how to change a simple map sensor setting. You dont even need to be touching your AEM.
Matt
Matt
Yep, that is why I try to stay away form making statements like your "super easy" one above. He admitted he hasn't a clue what he is doing with it so making things seem simpler than they are could lead to a big problem. Even though I know what you were getting at with that statement, a beginner wouldn't, as well as there bieng other problems with changing the MAP sensor, like the boost comp trim bieng thrown off, that could make a car barely even run before bieng addressed.
That is why I replied the way I did.
I can get you one on monday.
Email me to remind me.
if you need something by this weekend, you can email me and I should be able to send you one over by tonight. Please send in the email a complete list of everything on the car, and as others mentioned, it's only to start and drive(no boost).
Justin
I finally got my car started by richening up my warmup enrichment table. I just need to see a map with some semi tuned numbers so I know what kind of alterations to expect.
Can someone hook me up with a semi tuned map for 550cc and AEM 3.5bar?
Thanx
Thanx
have you tried the base map that came with the aem? I believe it is a 3.5bar sensor and stock fuel.
1 - 19 of 19 Posts
