1 - 9 of 9 Posts
Moderator, l337 M0d3r4t0r
Anyone know if this is possible... I know most people use the the nos map for meth but I plan on having both and I'd like to trigger them diffrently...
Any ideas, other then using a hobbs switch.
How are you going to have the nitrous setup? Wet or dry? What kind of fuel are you going to be using?
1,150+ rwhp club
Then you lose your two-step because derek's setup uses the alt fuel and spark trims. :(
-scott
you don't lose 2 step.
Vtec table to turn on pump relay
alt table with grounded wire from pump pressure switch.
if grounded wire from pressure switch is non exsistant/fails, then alt table kicks in less timing, more fuel etc. None of which has to do with 2 step.
I use a LS output to trigger mine which frees up the N02 control and keeps the 2 step. There are other ways to do it but this one works fine.
Discussion Starter #9
thanks guys, i'm planning to use a DRY kit since i have 950 CC injectors and only a 67MM DDB turbo so I figure there is plenty of left over injector.
James do you happen to have a test map that I could look at with this type of setup?
1 - 9 of 9 Posts
