1 - 2 of 2 Posts
When I'm driving with the a/c on and come to a stop. The rpm drops pretty low and stalls sometimes. When the a/c is on full blast, seems like the engine isn't geting enough power and stalls, when coming to a stop....
T88 YOU
do you have correct a/c idle load comp settings? should be like 5-10% with very low delay... if you are lost on what i am talking about: hook your computer up and run aem... click the idle button and go to the options window, near the bottom you will see idle a/c load comp window... adjust this with the car running until the rpm is exactly the same with the a/c on as it is with it off... then you can mess with the delay settings to keep the idle from raising until the compressor hits full load... hope this helps
1 - 2 of 2 Posts
