I have installed the Aem Tru Boost Controller/Guage and I can't get it to work.
I have the hose from the turbo compressor going into port 3 on the solenoid.
I have the hose from the wastegate actuator going into port 2 on the solenoid.
The Sintered Muffler is on port 1 of the solenoid.
I capped off the bottom of the wastegate actuator.
I capped off the nipple that the hose from the bottom of the wastegate actuator went to. (I think its the VSV)
The lights on the gauge are working and it is reading boost perfectly. The "wastegate crack pressure" is set to 12. I turned boost setting a and b all the way up to 90 and it still does nothing. It boosts up to 13 psi. It feels just like stock.
Can a wire be not connected? Is it just not turned on? What is wrong?
