I just installed this and noticed some pecularities. At idle it seems to fluctuate between 14.6-15.2, which I figure is normal and ok. Driving around it tends to stay in this region but it really seems to fluctuate around a lot more than I thought it would
Whenever I let off the gas, it goes super lean, i mean beyond 17 and the display shows the three out-of-range bars. Whether I am in gear or not, it does this. Is this normal?!?
I had it dynoed last week and the AFR looked very good, 14.5-15.5 and then around 12.5-13 at WOT (362rwhp on 93 gas, probably around 13-15psi as I cannot see the stupid hks evc screen to properly adjust it)
The sensor is mounted about midway down the dp, about 8-12 inches from turbos
thanks for any insight
