Found E85 NOT in NJ!
I was wondering how far I should install the O2 sensor away from the turbo because in the manual, it says 36in away from the turbo but what do you guys run
also is it okay to have the O2 sensor after the high flow cat converter or is that a big no-no?
No. The wideband keep it before the cat. Don't let it stay TOO close to the turbo. I'd say a good foot away atleast. 3 ft away is good as well.
Since we are on the subject of AEM wideband installation, where do you guys route the wideband wire through to connect it to the gauge in the cockpit?. And from what I've seen must of the aftermarket downpipes come with the wideband bung located about 1 foot from the turbo.
wastegate hose is pulled
Same place as a stock O2 sensor is fine. Ditch the cat converter if at all possible. Pretty sure they don't have "smog traps" in Jersey...
Run the wires thru the hole in the back of the fender. There is an extra grommet behind the back of the fender liner.
LoveHz
the "orange" one...
