1 - 7 of 7 Posts
boost life
my tuner alpha wants me to change my fpr because i get some inconsistent pressure drop under boost .. so we believe its either walbro dropping voltage and or fpr diaphram leaking under pressure
so question is i currently have the aeromotive fpr part# 13109 with -6an inlet outlet but i see most use the aeromotive part # 13101 with -10 inlet -6 return
is their any benefit to using the 13101 over the 13109
i am also installing a -10 fuel rail stepped down to -6an feed and return lines , line from tank to rail will also be -6an with a aeromotive fuel filter currently using rc 750 cc high imped
Boost Addicted.
I've got this same exact problem with my 88 1JZ, pressure drop to unsafe levels with boost upped, I suspect low voltage to the Walbro..... Also have an Aeromotive installed.... Can't run more than 13-14 PSI till I get it ironed out.....
1 - 7 of 7 Posts
