afm from a mk111
533 Views 5 Replies 4 Participants Last post by  suprafly79
will the turbo afm from a 90 mk111 bolt up on a 93.5 mkiv na
will this be considered a intake upgrade....will it help or harm the performance
Yes, they are identical.
The AFM from the V8 Lexus is larger diameter, and is a direct bolt-up. But I don't see any real advantage to doing this. You would need bigger fuel injectors to compensate for the larger AFM.
Toysport mentions an n/a vpc conversion but I'm not sure what type of n/a could benefit from it. They do both n/a & turbo hot rod imnports. The benefit of the vpc is greater, less resrictive flow as is the Lexus mod. No, I don't know anyone who has it.:(
I have a VPC on my car. It is really only gonna benefit a turbo'd car, as it allows you to use bigger injectors, and has some tuning functions. I don't think that the less restriction in the intake will amount to much. And for tuning your fuel you'd be better off getting a AFC instead.
Just asking because I'm not sure if a fipk will bolt up on the na afm.....i know it does on a mk111 t afm...so why not swap them out and upgrade the intake system.,....
