Anyone bought an aftermarket alternator and found out that the after market alternator pulley is bigger? Nice any difference with the bigger pulley? Will it cause any damage?
Mind if I do a J?
Bigger pulley is for cars with ATI damper. Use OEM alternator pulley if you’re running stock crank pulley.
as above ^^^ just saw that comment regarding using a bigger alt pulley for aftermarket crank pulley
I have a ATI damper just installed and a set of PHR pulleys. Is there a need to run a bigger alt pulley?
Swagger Wagon
In for answers, I have a ATI Damper from Titan
I heard you can kill alts at high RPM (8000) was planning to switch alt pulley but haven't done so yet.
