1 - 2 of 2 Posts
I'm in the process of installing a Pioneer deck and noticed that the harness that I bought does not fit the one in the MKIV. I went to audio shops and they said they don't make one and that I'll have to cut into the factory harness. Does anyone have a harness for the MKIV? because I know many people have aftermarket decks. If I was going to cut into the factory harness, what's the color codes for the wires on the harness? My last question is what is the other plug right next to the antenna wire on the factory double-din deck? it looks just like a antenna wire, but smaller.
any help would be appreciated. Thanks in advance,
Poser Extraordinaire
your trying to plug into the wrong harness. the proper harness is in the back right section below the radio, you have to disconnect what is already plugged in and then plug your new harness into it.
i am assuming your trying to plug into the harness you pulled from your stock head unit, however this will not work, by using an aftermarket head unit you bypass the stock amp and subwoofer,
i hope my description helped
Ting
1 - 2 of 2 Posts
