Aftermarket (Walbro) Fuel Pump
1598 Views 13 Replies 3 Participants Last post by  Zepher WS6
OK, my question is . . . what aftermarket fuel pump can I go with to replace the stock one that can flow a little more than the stock one reliably? I am guessing a Walbro pump, does anyone know which model, and does anyone have experience with this? And, does anyone know where I can order this bad boy?
Also, does anyone know the flow rates of the stock fuel pump?
Thanks, in advance, everyone.
1 - 14 of 14 Posts
I picked up one GSS341 to run with my stock pump, you can compare the flow rates at the link below. I purchased mine from Lar, PHR also sells a higher flowing Walbro for a little more money.
Walbro
also
Rates
Melvin
im gonna jump in on this thread and ask something...
is there any single external pump that will supply enough for around 650-700 rwhp by itself? if so which one and how much. thanx.
i am worried about getting twin stock pumps for my single because it was discussed in another thread that if one failed, then by the time you figured it out, (a high boost run) your engine could lean out and blow.
Andy, that could happen to any pump....at any given time, you could also have a blow out at a high speed run. Not putting your concerns down, but anything could happen at any given time.
But to answer your question, if you go to the MKIV tech articles you'll find that Nick used an external pump. Not quite sure how much the pump flow but I'm sure with the name of the pump you can find out.
As far as twin stock pumps, if you look at the test, when the stock pumps are operated in 12v mode, they draw quite a bit of current compared to the Walbro at 12v. So I plan to run my stock pump in the switched mode and the Walbro in 12v mode.
Hopefully someone with more experience will chime in....
Melvin
A Granatelli Signature Series EFI Fuel Pump would flow enough for 650rwhp, but is very, very loud. External pumps also tend to overheat in rush hour traffic (no air flowing over them to cool them off).
Melvin
but if this happened with only one pump, then wouldnt the car just die, instead of with two pumps if one quit then it just wouldnt get enough fuel and then run lean?
Good point. Not sure what would happen though.
Phil gave good info on the external pump...
Melvin
Well, my question was about REPLACING the stock pump completely with just a Walbro upgraded one. Based on the opinions of others, I ordered an FPD003 kit which is for an earlier DSM, but comes with the GSS341 pump . . . should work? This will flow more than the stock pump, right?
lilviv, if you look at the chart you'll see that a single Walbro will flow almost as much as the stock Supra pump but at less current ,sounds to me like the Walbro is more efficient, using dual Walbro's will get you almost twice the flow of a single stock pump using less current...
In my setup, like I said, I'm using a stock pump plus a Walbro, the stock will work in the switched mode and the Walbro in 12v. I've heard of people using 2 stock pumps because they say the stockers last longer than the Walbro. But how long the stockers would last running at a constant 12v drawing the kind of currnent they draw is another thread.
I would not recommend a single Walbro making the kind of power you're making, plus you plan to upgrade you injectors correct?
Well, I do not plan on upgrading injectors . . . and, I figured I didn't need to 'cause my Nitrous system is injecting fuel before the throttle body mixed with Nitrous Oxide?
Also, where is this chart you are referring to? You don't think it has a higher flow capacity and/or reliability than the stock one? Thanks.
Walbro
also
Rates
Melvin
The links are above, click on Rates and Walbro, they are both links
Man, does this mean that I will be worse off than a stock pump with the Walbro GSS341? Sigh. =(
I got it for a little under 125 dollars shipped and after tax.
Mohd sent me this URL:
Fuel Pump Info.
On there are two separate charts, one has the GSS341, and one has the stock Supra fuel pump.
Can someone formulate decent opinions based on those charts?
Just have a Fuel Pressure gauge installed in the car and monitor it closely when you are racing, if the pressure drops when you are running, shut the car down.
See less See more
1 - 14 of 14 Posts
