I just searched around, saw some pictures, but instead of bumping like 6 different posts I figured to make my own so we can consolidate the information. I remember some of you guys doing your own wiring harnesses and making the harnesses from scratch. Like some of that fancy wire looms. Well I am not doing that, but will be wiring up a 54 Ford F-100. The fuse box kit has all the wiring already done, but doesnt have quick disconnects between the switches and fuse box. I want to add these in for ease of use when removing things like the door panel for maintenance or what not.
Where did some of you guys get your weather proof & non weather proof connectors from? They can be pre wired or I can install the pins & wire into the sockets. They can also be military spec if that is all you know.
Let me know what your using and a link of where to look at it.
I have found a few, but I'd really appreciate your input on what you did and what/if you would do different this time.
Thanks guys,
Thanks guys,
