1 - 14 of 14 Posts
No One Ever Listens To Me
my lovely great friend decided to mix up the piston and rods numbers when we were installing new rings and bearings.....
what can i do?
is there anyway to tell what number they are from looking at them?
also its a rebuild......so ive got new rings and new bearings...new fasteners(ARP) and ive gotten the cylinders honed....can i just put them in any order now? since its basically all new stuff?
whats the deal guys...help me please asap!!!!
If its a rebuild (everything should have been balanced)... so the order shouldn't matter.
However, if your machinist was good... he would have stamped numbers on the rods and caps.
"DANNY TANNER!!!"
do you have brand new pistons???? if you do then i don't think there is a problem. If you are using your old existing original pistons then there might be a problem because each piston is somewhat married to that specific cylinder. Make sure your end gaps are ok.
***ified?
I think it would depend on how the motor was balanced also - as an assembly or separately. Get a micrometer and measure everything. check all of your ring gaps. Plastigauge everything. Once you get it figured out, write on it with black marker to label the order.
Were the rods and pistons balanced together? I'd imagine that specific rods go with specific pistons from a balance persepctive at least. Did he mix up rod caps or full rods with the pistons?
the clever guy
The engine is completely factory blue-printed and you can use the tsrm to place untouched parts back where they go like your pistons. Personally, I used toyota bearings all around so mains were easy to set up (per tsrm) and I had my machinist resize my rods to factory specs with arps. IMO, you can get away with plastiguage(like I did) but measuring clearances is ideal.
***ified?
the stock stamps on the cut line of the rods should coincide with oneanother. If they dont match you obviously have them mixed up.
1 - 14 of 14 Posts
