My airbag light is always on. Yes, I pulled the codes and had a 15 (front sensor) and a 41 (malfunction). I cleared the Code 15 (improperly joined connector) and now can't clear the Code 41 which just indicates that there WAS a malfunction. I tried the grounding trick, disconnecting the battery and fuse ECU-B as detailed in the TSRM but the code just won't go away. Any ideas??? BTW the car is a 1990.
