1 - 18 of 18 Posts
Offical MkIII Pushman
i search found a thread where Acroth had the air cylinders so that wasnt the same thing. only found 4 threads, was wondering any one got the actual air bags, and or dose any one know where to pick some up?
/me see's flaming soon :/
i was also thinking bout an air ride suspension. just because it would be nice to be able to go from low to high for going over speed bumps and such within seconds. it would be a softer ride too... but maybe wouldnt handle as good...
yea thats the main reason why i am interested in it for the quick changing of the ride hight. go to stock ride hight when your driving around lower it when your parked or what ever you want heh.
talk to acroth(i think thats his sn) he had airbags and if i remember correctly he hated them and switched to coilovers
josh
1.5JZ Turbo Supra
I've seen tests done on TV with real every day drivers and air bags handle great. They help on everything. Don't really know if they are better then coilovers tho.
josh
like i said in my first post acoth had the air cylinders they are different from the air bag's. from my understanding what he had would transfer the air when you would turn, these are self contained and alot more effective.
http://www.supraforums.com/forum/showpost.php?p=2402698&postcount=35
sorry didnt read the first post just went right off the reply and the topic
I got air bags on my Mustang and love them. You can raise up to go over a speed bump then deflate to lay the K member on the ground. Plus if you go with 1/2 valves and lines you will be able to inflate quicker. Mine raise and fall in less then 1 second. But plan on paying more then $1000. My bags and brackets alone were $775 and I put the rest of the kit together myself. Let me know if you are interested and I'll go look up my reciets and give you some ideas on places to get the stuff. It took me about 4 hours every day after work for 5 days to completely install mine. And thats in the beguinning of January :)
also there is usuallya reason for going with cylinders over bags like sometimes i dont know if it applies to our car but i think some civics have to have cylidners and not bags because the bags wont fit. If you do get an air ride (which i had on my old car and learned to hate honestly) and you have to get cylinders make sure to get the dump tanks one for each axle taht is what smoohts the ride out alot with cylninders......
they don't fit because of the strut assy. You would have to go with an air strut which is the same thing. Gives a better ride.
the firestone system for the wrx is atypical when it comes to air suspension. When you lower the height of a car with airbags you do so by lowering the pressure in the air "spring" itself. This effectively reduces your spring rate, the inverse of what you actually want. Common sense would tell you that the lower your car is, the stiffer you want your springs to be to avoid bottoming out. The firestone system counters this with adjustable dampers that stiffen considerably as ride height decreases. Sport Compact Car had the firestone suspension on their wrx and ditched it for a nice set of coilovers. They loved the way the air suspension handled at the track, but deemed it too harsh for daily use. Talk to Acroth and he'll probably point you to a decent set of coilovers. I hope some of this rambling helped somebody, I just kinda felt like typing.
Zach
MKIII Bodykit Connoisseur
mine were self contained as well.. they were air cylinders... and the ride stability just sucked... it wouldn't transfer air between the cylinders, it just felt like jello suspension whenever i'd drive....
i've heard that air-struts work a lot better and have a more stable ride... but i love my tein flex coilovers so goodluck with whatever you go with man :)
1 - 18 of 18 Posts
