21 - 40 of 45 Posts
Discussion Starter · #24 · (Edited)
Sorry for the lack of updates. Been very busy with my new build and other stuff. Regardless, none of the other manufacturer's got back to me with any info :sleep:. I updated the K1 rods and Mahle pistons with the actual data from weighing mine. Pistons came in 21g heavier since they were quoting me for their 4032 version and not the 2618 version that I bought. But they are still lighter than others in the list when assuming the same pin thickness and everything else for total weight. I really wish someone with a new CP setup would weigh theirs since they are the most popular. Also, my K1 Rods came in 3g lighter than they were supposed to. Lastly, I added the Tomei H Beams that someone posted above. Thanks for the Tomei info!
Good to know. Nice thread.
titan street pistons
this is the je printout for the titan street pistons
Discussion Starter · #28 ·
Posting my findings
weisco pistons and k1 rods
Thanks for the adding to the thread. Those Wisecos sure do look really nice! I added the Wiseco info above, and adjusted the K1 weight down 1g to split the difference between yours and mine. Glad to see someone else trying out the K1's. Good luck with your build and take care sir!
just a qiick thought. Ive read that the vvti rods are smaller than the non vvti rods. Is there any weight difference?? If so what is it??
further research indicates they are the same
As someone mentioned, the non-turbo GE VVT-i rods are much lighter, but it's definitely not a good thing. Those things are twigs and will snap as early as 400whp!
here numbers on piston rings
exempel 1.0mmX3.0mm and force to the cylinder wall 900gram gap 0,40mm
Mahle
1ND 1,2mmX3,0mm - 720 gram
2ND 1,2mmX3,4mm - 740 gram
Oil 2,8mmX3,5mm - -----------
Wössner
1ND 1,5mmX3,2mm - 1060 gram
2ND 1,2mmX3,4mm - 940 gram
Oil 2,5mmX3,5mm - ------------
JE
1ND 1,2mmX3,1mm - 800 gram
2ND 1,5mmX3,9mm - 1040 gram
Oil 3,0mmX2,5mm - ------------
CP
2ND 1,5mmX3,1mm - 1040gram
HKS
1ND 1,0mmX3,2mm - 780 gram
2ND 1,2mmX3,6mm - 960 gram
Oil 2,0mmX2,8mm - 2700 gram
OEM
1ND 1,5mmX3,4mm - 1460 gram
2ND 1,5mmX3,9mm - 1120 gram
Oil 3,0mmX4,0mm - -----------
Ross
1ND ------------------ - 1200 gram
2ND ------------------ - 880 gram
Oil -------------------- - -----------
i am measuret al so the Arias rings i kant not found the exact numbers what i know is it prety close to the OEM rings.
Discussion Starter · #32 ·
Mahle
Wössner
JE
CP
HKS
OEM
Ross
I am not sure I understand all these numbers or where they fit in above? Please explain. Thanks!
a) is radial wall thicknes
b) is axial width
example Mahle 1ND ring a=1,2mm b=3,0mm this fitting to the piston ring groove
Mahle
1ND - 720 gram force
2ND - 740 gram force
1460 gram force X 6= 8760 gram force
OEM
1ND - 1460 gram force
2ND - 1120 gram force
2580 gram force X 6= 15480 gram force
this is a friction reduction of 43% on the rings in all 6 cylinders
Discussion Starter · #36 ·
b) is axial width
Mahle
OEM
Oh I see, and thanks for explaining, but I think thats a little more detail than I want to put into the charts above. My charts are really just for all the physical weights of all the rods and pistons. Thanks for adding the info though and take care!
Piston
Mahle 3,0 86,50mm 313 gram
HKS stroker 87,00mm 344 gram
Wössner stroker 87,00mm 306 gram
Wössner stroker 86,50mm 303 gram
Rods
Maxspeedingrod H-Beam with bolts 634 gram
Wössner H-Beam with bolts 570 gram
Discussion Starter · #38 ·
Piston
Rods
Have you personally hand weighed these items, or did you just get the info from a website somewhere? Some of those numbers contradict what I have seen elsewhere is the only reason I am asking. I just bought Mahle and weighed them myself, and they are no where near 313g. Thanks!
yes i have personally weighed the parts, i have two sets of Mahle
with the JE Piston 86,50mm i mesure 330 gram what you mesuret to.
Discussion Starter · #40 ·
OK, your JE numbers match up on the piston. Did you happen to measure the rings, pin, clips weight?
On the Mahle, they make two different versions for the 2JZ. Do you know which model number you bought. They make a 4032 and a 2618. I bought the 2618 ones and they weigh 340g, so maybe you have the 4032 ones which should be lighter. Please check on that if you wouldnt mind. Thanks!
21 - 40 of 45 Posts
