41 - 45 of 45 Posts
OK, your JE numbers match up on the piston. Did you happen to measure the rings, pin, clips weight?
On the Mahle, they make two different versions for the 2JZ. Do you know which model number you bought. They make a 4032 and a 2618. I bought the 2618 ones and they weigh 340g, so maybe you have the 4032 ones which should be lighter. Please check on that if you wouldnt mind. Thanks!
here i have sam pictures from the Mahle Piston
the pin have 101g
Discussion Starter · #42 · (Edited)
OK, I will add that info up above to the chart, but you have the Powerpak version which uses 4032 material for the pistons, which is also why it is lighter than mine. I have the Powerpak Plus ones that weigh a little more and are made of 2618 material. I'll have both in the cahrt and thank you for adding the info!
Can you verify which of the weights you have listed were weighed by you personally, besides the Mahle, and which ones were just pulled from the internet? Thanks in advance!
Hi Mate
these are all parts which i myself have weighed for the 2 JZ-GTE
the ring force i m have mesured to
Piston
Mahle 86,50mm 313g, pin 101g
JE 86,50mm 330g, pin 97g
Jun (C) 87,00mm 342g, pin 99g
HKS Stroker 87,00mm 344g, pin 110g
Wössner stroker 87,00mm 306g, pin 98g
Wössner stroker 86,50mm 303g, pin 98g
Rod
Maxspeedingrod H-Beam 634g
Wössner H-Beam 570g
Jun I- Beam 590g
Carrillo H-Beam 594g
Carrillo (HKS stroker) H-Beam 600g
Discussion Starter · #45 ·
Hi Mate
Piston
Rod
Wössner H-Beam 570g
Jun I- Beam 590g
Thanks for all the updates. I have added everything above.
41 - 45 of 45 Posts
