1 - 14 of 14 Posts
I just got my bar back from the shop. I had it tuned and am putting down a normal 450whp.
Mods are
T78
SAFC VPC Profec B
Stock Fuel
Greddy FMIC
Fuel pressure regulator (keep an eye on things)
Now i might have come from an ok powered car (WRX at 200whp) to my supra. But damn this thing is freakin crazy. It just keeps pulling like a beast. I can't believe all of you crazy people with 7,8,900-1200whp that is just insane. How do you keep you tires on the road, cause i break loose at 50 like its nothing. I myself have Volk GTC's with 285's on the back with decently sticky rubber. Seriously, can you drive those things.
P.S. This is all coming from a hypocrite who will going for 600's in a couple months :)
Josh
Spinning the tires at that high of MPH is scary. Not long ago my friend Josh gave me a ride in his supra. He was still rockin regular street tires and it was pretty cold out. Sure put alittle scare in me.
I would deffenetly suggest you pickup some good tires.
Have fun and be safe.
I'm back!
Mods are
T78
SAFC VPC Profec B
Stock Fuel
Greddy FMIC
Josh
LOL....450whp pulls like a beast?? :) Breaking loose at 50?? Mine brakes loose at 100+.
I have broken loose at 100+ mph on cold, dry asphalt in winter in 4th gear, with my old 61. :eek4dance I learned back then to take it easy in winter and not even bother with high boost.
In dry, warm weather I have no problem hooking 550+ RWHP with 295/35-18 MXs and a little driving techniuqe, that is my fav power level. Much more and you blow the tires off (1st and 2nd only), less and it feels a bit slow (after getting used to 550 :) ).
The best feeling I have ever had in my Supra was a 600 RWHP, 5th gear roll on at 140+ mph, still put back hard in the seat. :bigthumb:
Hawtness
those are the exact numbers im looking for.
you get used to it. I've got 800+ right now btu want to go to the next level, investing in some good traction control to save my ass before I take the plunge to 1200-1400 hp :) Boost/ Speed makes life much more enjoyable as well in getting the most out of the tires you choose to use.
1400rwhp/8 Sec Club
Yea i took my car out on the highway again the other day.... and its definetly a handful when you get up there in power... on et streets rolling the tires off in 1st,2nd,3rd, and part of 4th... it gets your blood going for sure!
Senior Member
low-mid 600's on pump and have no problems keeping traction.
I have a racelogic and havent even installed it because I dont seem to need it.
Go figure
:1poke:
Not going to see too much difference without moving up to drag radials. Some tire will hook better than others but once you cross a certain mark no "street tire" will offer proper traction.
Boost Junkie
I have an auto with a 3800 rpms stall, built toyo trans, and a 67mm turbo w/cams. At 23psi-around 525whp, I have good success starting a pull around 45-50mph with my BFG KDs-315/35/17. This is in warm weather and on concrete of course. At 29psi (around 585whp) I have to start at more like 65-70mph to keep it from spinning. I like these tires because they are sticky yet you can still hit the corners really hard with them. I figure if I start making more power I'll have to invest in a drag radial so now is a good time to stop;)
Steve
Discussion Starter · #13 ·
Steve
Those BFG KDs are the ones that i am thinking i have to go with next. Right now the 285 sumitomo's aren't cutting it. I think i will be just shy of the need for race logic when i am done tuning (around 600whp). Seriously tho, you guy's/girls with 800+ hp all you need are wings and you can fly. :wtflol:
The Hustler
Drag Radials are a Must!!!! My car would hook pretty good till I turned it up to ABOUT 750rwhp. Anything past that you better be paying attention! HA.
1 - 14 of 14 Posts
