1 - 20 of 57 Posts
yeah thats me!
lookin good... cant wait till im almost done.... well my wallet will be happy :)
looks great!
-ian
I'll nevAr go single!
Thats fuckin Beautiful man, I hope mine looks 1/8 that clean when im done.
Your Neighborhood Pikey
Thank you! I actually need to clean it because it's dirty right now and the flasher from the camera drowns out everything. Once it's running I will do a thorough cleaning again.
- Chris
congrats man. I'm glad that you got all the little details worked out. I'm still awaiting word on my car. As soon as i get it, i'll send you the email.
Bryan
Moderator, l337 M0d3r4t0r
can't wait... hams give me an update when you get everything running.
Over 10 years on SF....
Video now!
turbo....................
thats looking awesome, make sure you get vids of the beast :)
Discussion Starter #13
Well it cranks but no fire. I think something is up with the Crower cams... When zero'd out, it sputters and tries to start but can't get going under it's own power. I advanced the cam 5 degrees just to see and it wont even try to fire now. I'm going to retard it and see what happens. That should tell me if the cam really is the issue. If so, then I'll put the stock cams back in the car and get a set of HKS 272's.
Needless to say I'm a little depressed this morning.
- Chris
Hey Hams, we all have your support. Dont get down over your project, you have come a lot farther than a lot of us! Keep up the good work and I'm sure it will work out fine. Keep us posted!
Discussion Starter #15
UPDATE!
It runs! I spoke with Eric (Zazzn) the other night... He had mentioned on his Crower cams that he pulled off his pcv line and then advanced his intake cam. I did the same thing and guess what? It started up no problem and ran!
At this point due to time constraints, I am going to swap out the Crowers for the stock cams so that the car will run.
Just so you guys know, I was not involved in the Crower GB. I had purchased a set of Crower Stage 2's for my MKIV and ended up machining them for my 1JZ. It seems that the 1JZ does NOT like them.
I think at this point I might consider a set of JUN 272's or HKS 272's for my car.
First thing's first, I need the car running so I can drive it to my new home in Ft. Worth.
Oh Eric... With the pcv line removed, my car was idling at 1200 on a cold idle, and there was no lope on the motor. I couldn't tell that there were cams in the car.
Well, back to you guys later! I am out to the garage to swap cams and get this car running.
- Chris
Moderator
Awesome Chris glade everything worked out.
Discussion Starter #17
WOW!!!!
It's done, what else can I say!? I haven't driven it yet but upon startup and revving the motor.... WOW... It revs REALLY fast now, extremely responsive. I'm getting boost with my 67 just by revving it now. I'm impressed. This car is going to be straight up scary.
I have the video but I need someone to host it for me...
Simply.... WOW.
Chris
Hams, that thing is FUCKING AWESOME!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :bigthumb:
1 - 20 of 57 Posts
