1 - 13 of 13 Posts
Hi guys
I was wondering if anyone can recommend a good after market High Output alternator. Last Week I ordered a 220 Amp High output Alternator from Powermaxx seller on ebay. Installed it in car idled fine for 30 minutes and was charging great, until I decided to rev the car thats when the alternator took a dump.
I called them because they are local and ran over there and grab another alternator this time a 200 AMP alternator and it did the same thing.
Turns out the rotor went bad on both of them.
Can anyone guide me to a dependable alternator. My mechanic thinks I am putting too much load on the factory alternator because I am running a twin pump setup and electric fans
Boost Junkie
I am switching to the Sequoia LTD alternator listed above as well.
Steve
boost life
also try mechman .. no issues here with 170amp , it outputs approx. 139 amps at idle .. firend has 1400 hp supra using same alt revving to 9k and has zero issues maintaining almost 14 volts output hot
What size is the pulley? Are you running it with an OEM timing belt?
Cardinals!
There are two Toyota alternators that are nearly a direct fit upgrade.. the 130A Tundra/Sequioa and the 150A Sequoia alternators. Shave about 5mm from one of the ears, and re-pin the connector (less than $10 from Elmhurst for a new connector) is all you have to do.
Is the 2JZ alternator pulley identical to the 2uzfe pulley, or do you have to swap it over?
Also in this thread
http://www.supraforums.com/forum/showthread.php?683340-130-amp-OEM-alternator-for-the-JZ-engines!&
one person - carchitect- mentioned shaving 1mm off the sleeve from the lower ear but no one else has and 7mm off the top ear...
do we know for a fact that the top 5mm shave will line up the pulley with the belt perfectly
[/url]tundra alt upgrade by https://www.flickr.com/photos/[email protected]/, on Flickr[/IMG]
Im a little confused i thought the middle ear with the sleeve is supposed to get cut off?
[/url]sequoia150amp by https://www.flickr.com/photos/[email protected]/, on Flickr[/IMG]
What connector do I need to get to repin with this alternator? Also where do we shave off 5mm?
1 - 13 of 13 Posts
