Hi, does anyone know what is the differences between the normal RS200 and the L and Z edition? Also is qualitat better? because I've seen qualitat come in 4 and 6 cylinders. Thanks
Also if you were to buy an altezza, would you get the 6spd or the 5 speed tiptronic with steering button changers?
And is the sat-nav screen any good? can you use it to connect your own say dvd player or other video input?
As far as I know the Altezza never made it to the US - best people to ask would be the Import, Altezza forum on Lexus Owners Club UK. They should be able to answer all your questions :). Hope that helps.
Wangan Nasty
the RS200 came with the BEAMS (Breakthrough Engine w/ Active Mechanism System) BLACKTOP 3s-ge. Made about 210 Naturally aspirated horsepower out of a 2.0L 4 cylinder. Transmission was a 6 speed gearbox.
Altezza also came in a BEAMS 1g-fe model called the AS200, was a 2.0L Inline 6 with the BEAMS sytem and was made more for touring.
The Wagon/Gita model came with the 1g or 2jz-ge NA engine.
The L and Z edition are just different options for interior and paint packages. Optional Aero kits (IS300 L-Tuned) are also available.
