I believe the actual car is a Celica TCT Twincam Turbo TA64 - aka the Celica GT-TS. 4T-GTE is the engine I think and I believe its 290hp but it changed drastically in its life.
Although I dont think it is, it may be an RA63 which ihas a bit different of an engine - specs -
http://www.rallye-info.com/carspecs.asp?car=222
Btu It hink the RA63 was a later model, this should be an TA64.
TA64 specs:
Celica Twincam Turbo
Official name Celica Twincam Turbo
Generation 3
Model Code TA64 TTE
Chassis Code
release date 1983
final date 1986
Comments Group B Rally monster From TTE (Team Toyota Europe).
Engine
Code 4T-GTE
Aspiration turbo (KKK/K27)
Cylinders 4
Valves/Cylinder 2
Valves 8
displacement 2090cm<sup>3</sup>
Bore 89.0mm
Stroke 84.0mm
Bore/Stroke Ratio 1.060
Compression ratio 8.0:1
Power output
[email protected] (364bhp)
Torque output
[email protected] (361lb/ft)
Power over displacement 129.732kW/1000cm<sup>3</sup> (173.974bhp/l)
Torque over displacement 234.450Nm/1000cm<sup>3</sup> (172.921lb/ft/l)
Fuel
Alternator
Battery
Head material
Block material
Ignition electronic
Injection NipponDenso Mechanical
Cooling air cooled intercooler
Cams twin overhead
Cam drive
Drivetrain
Transmission 5 speed manual
gear ratios
Final drive
Performance
Fuel Economy
Measurements
Length 4.284m (14' 0.7")
Width 1.785m (5' 10.3")
Height 1.310m (4' 3.6")
Wheel Base 2.500m (8' 2.4")
track width Front: 1.410m
Rear: 1.400m
mass 1100kg
fuel capacity
oil capacity
coolant capacity
Drag coefficient
Steering Wheel Rotations
Brakes
Brake System Features anchors
Front ventilated discs
Rear ventilated discs
