1 - 11 of 11 Posts
I took my cam covers off to replace the gaskets, when I put every thing back together the check engine light was on. When I pull the codes the light flashes 4 times and stops flashes once and stops flashes once again and stops, then flashes 7 times. I tried to reset the ecu, the light stayed off for a while but then came back on. Thanks for any help.
ok, then are you sure you counted 7 flashes ?
I doubled checked the mkiv. com obd1 list,
and i DO NOT see a error code 17 listed. You got me stumped.
check the throttle position sensor first off and go from there....
ahhh......that makes ALOT more sense. Error Code 14 = Ignition Signal , and error 71 = EGR System. Sorry i cant help you with 14, but i had 71 before. All it was for me was one of the vaccuum lines had somehow came off. PUttin it back in and it fixed the problem. So check around your EGR and check all of the hoses. I know theres one hose back there that's known to rip. Is there any evident exhaust soot (sp?) in your engine bay?
Discussion Starter · #10 ·
Thanks for the help mystic. I've been meaning to get the block off plates for the EGR, so that should take care of that. One of my plugs on my coil pack came apart, so I'm sure thats were thats coming from. I'm going to call Curt and order new plugs for the coil packs. Just about all of the clips are cracked or broke off.
Thanks again for the help,
Justin
1 - 11 of 11 Posts
