I did the mod with the block off plate and the resistor but my "trac off", "check eng", and MIL light keep showing up. I have checked everything over and it looks okay to me. What could be wrong?
either the resistor is bad or it is not making contact with the wire. Recheck that part of the install. make sure you have teh resistor on the opposite side of the EGR ie. the side which does not connect with the egr anymore.
Okay I will put in a new resistor. But I have one more question. If the block off plate is in place and the resisor is in, do you need to plug the 2 EGR discs w/ vaccum caps?
