1 - 12 of 12 Posts
· Oldie but a Goodie
Well, heard my first turbo death whine in person yesterday... which sucks cause i had just finished making my test pipe a half hour before that. Well, if anyone is interested on how long to4e 50-trim CT-26's last under hard driving... its about 9k miles.
Time to look into SP's lineup.
my turbo is making a wierd noise since i put my ssqv bov on. i have it hooked up right and squeeks freakin loud and long but it kinda sounds like my turbo is like wierd.
got a sound clip?
not at the moment but i'll try to get one within a day or so. I still would like someone else to confirm the sound but i'm 99% sure that it's the turbo based on the fact that i only hear it during boost. Checked shaft play and there isn't any axial but there is a decent amount of radial.. can't tell if it is out of spec but i'm pretty sure that it is.
Might want to check some other things out before considering it dead. My turbo was making a sound that sounded just like the turbo death whine but it turned out to be my wastegate not closing all the way, which in turn make a whining noise. Couple of washers fixed that problem :D. Also other members have had similar death whine noises resulting in bad exhaust gaskets. Definitly check out thing like that which could be causing a similar noise. But after all, it is an upgraded ct-26 so i'm not saying it cant be death whine considering a good amount of the upgraded ct's go out pretty quickly.
Well, the wastegate is already shimmed (have been running 10psi) and again i doubt that it would be a bad exhaust gasket because it only makes the sound under boost. I'm going to look into things further before scrapping it but i highly doubt i'm going to catch an easy break on this one.
Yeah check where the turbo bolts on to the exhaust manifold. Ive experienced death whine twice and i also had the bolts come loose where the turbo bolts onto the mani and it sounded the exact same as death whine just thought i would let u know.
Well i checked those bolts and yeah, they were all pretty damn loose. However, even after tightening them back up it still whines :(
· Stormcock approves
When I got whine on my stock CT, I couldn't make more than 2-3 psi. Of course mine conveniently occured half-way between home and college. 150 miles on a flatbed is expensive.
1 - 12 of 12 Posts
