1 - 3 of 3 Posts
Hardtopper
I searched but nothing came up with my situation.
I am not using the stock radio harness at all, so the harness is off to the side.. I ran my own power, speaker wires, etc.... Only thing I have left is the antenna.. since I am not using the harness will it be any different? when I searched something came up about a blue wire and a pink wire... the blue wire is getting 12v to it as soon as the car starts.. and pink isn't.. so Iam skeptical about splicing those two together AND the antenna switch wire from my headunit.
I don't want to blow anything that I don't have to... maybe I was reading it wrong... can someone clear this up for me? Thanks
Hardtopper
Discussion Starter · #2 ·
Found this now
This is the one you want to hook up to the black/red and pink/blue factory wires.
Before I set something on fire can someone confirm this..
So on the actual harness for the antenna relay I can tap into the black/red and pink/blue to the antenna switch on my headunit and it will work?
1 - 3 of 3 Posts
