1 - 9 of 9 Posts
1989 7mgte swapped mk3
so I was drivin around today after doin yardwork for some guy and I pull up to sonnys to eat and put the parkin brake on and let off the brake. The antilock brake light then comes on so I tap the brake a few times thinkin maybe it'll do somethin, but it didn't go off and is still on...any ideas?
how would air be gettin in there if it is....goin out there now to check the level...
fluid looked good...went out there and turned the ignition on, but not the car and it didn't stay on. Maybe I need to start it, but i'm waitin until tomorra...gas is like close to 2 bucks per gallon now.
dang...it's been like 1.70 for awhile, but it's really shot up...probably not comin back down for awhile either
No One Ever Listens To Me
AGlobalThreat said:
Could be a bad cap or a leak/break in the line. My BRAKE light was stuck on for 2 days, and then the 3rd day it went off like it's supposed to.
i know this seems like im stalking you now heh but im not just trying to post RELEVANT info ;)
the things you mentioned will do exactly what you mentioned...turn the BRAKE light on... the ANTILOCK light is a different story...
you can also find out exactly what is causing the problem by pulling the codes from it...
here ya go follow this:
http://cygnusx1.net/supra/library/TSRM/br/BR_52.html
and heres the codes:
http://cygnusx1.net/supra/library/TSRM/br/BR_53.html
hope that helps
92 TURBO
^ He's stated that his "Antilock light" [ABS] is on and you'll talking about your "BRAKE" light. They're 2 different things.
1 - 9 of 9 Posts
