·there are 3 kits available. which one is the right one?
aquamist
how many hours does it usually take to install a water- injectionkit? do you set the waternozzle before or after a fmic or before the throttle body? or do you set 2 or 3 nozzles?
what is the estimated hp gain with a water-injection kit on bpu? where did you place the water tank on your cars? how much volume has your tank? and how long do you usually drive arround with one water-injection-tank? when the water injection begins to spray into the fmic pipes does it change the a/f ratio? is it leaner or richer or the same?
sorry to ask so much but I can't find any other guys to help me out with this
aquamist
