1 - 9 of 9 Posts
Escaped from infinite lag
the only difference is the intake cam. as long as you put your turbo cams in it you'll be fine.
depending on the turbo setup and you may want to run the NA cams.
Overlooked
Nothing now but it was somthing like .01 difference on the lift on the turbo cam (part numbers are the same now). People say the NA cam is better for scavaging (even thought they are the same) but you don't want that on a turbo car.
1 - 9 of 9 Posts
